I would like to put a condition on a workflow condition that requires the user to either include an attachment or a link to the issue before they continue. Is this possible?
I know this is really old but this is the way I did it. I needed the user to have an attachment called ReadMe.txt so I added the following scripted validator and it works.
Script workflow function : Simple scripted validator : Checks script:
issue.getAttachments().find {it.filename.contains("ReadMe.txt")}
Unfortunately it is case sensitive. I will have to find a way to .ignoreCase
This did it: issue.getAttachments().find {it.filename.toLowerCase().contains("readme.txt")}
Think there is a way to make that check for a null value on the filename?
I am sure there is but would have to play. Right off I would try:
! (issue.getAttachments().find {it.filename} )
Robert, thanks for posting this - Did not matter that it was a years old thread, just made my day!
Cheers :)
Hi @Robert G. Nadon,
great post!
I am trying to accomplish validating that there is an attachment with the following naming "PR Form"
I added a validation to the workflow transition but is does not work. any suggestions?
issue.getAttachments().find {it.filename.contains("PR Form")}
First off you need to have the script running plugin. I would make sure that is bought and enabled. After that there is a space within "PR Form" That is not good for filenames. I would see if you change both filename and query to "PRForm" and see if that works. Also to avoid case sensitivity maybe try:
issue.getAttachments().find {it.filename.toLowerCase().contains("PRForm")}
Also @Brian W. Bishop I have no idea how to check for a null filename. How would you even create a file without a filename?!?
@Robert G. Nadon- thanks for the quick replay!
worked for me!
another thing-
if i want this validation to work only if another costume field is X can I do it?
For example, this validation should work only if "Animal Type = Dog"
You bet google around and you should find the answer. That's how I do it :) I did a quick google and found:
getCustomFieldValue("Severity")
so This would probably work
if ((issue.getAttachments().find {it.filename.contains("PR Form")}) and (getCustomFieldValue("AnimalType") == "Dog") )
{ Do the dog thing }
Or something like that. You may need the function ToString() as well as I have needed that before.
Best Luck...
...Robert
Can't seem to find a condition but there is a validator in JIRA Misc Workflow Extensions.
Thanks for the response. We decided to require the links to be a URL custom field, so we could check to make sure that field was not empty. There was also a script condition that allowed to check for 1 or more attachments present befor allowing the transition
Register now
