Hi while doing one transition alone its loading too much time and after that its showing like timed out this is happening for only one transition in the issue give me your suggesstions.
This is the error its throwing
The call to the JIRA server did not complete within the timeout period. We are unsure of the result of this operation.
Close this dialog and press refresh in your browser
Hi!
Any errors in console log and server sde also?
Gonchik Tsymzhitov
but if thr is server side error means all transition ill not work , my query is about only one perticular transition is not working
You need to read the log file on the server to see why it is timing out
