Workflow Validation Script
Arijit Banerjee January 17, 2016
I have a Workflow validation script as below:
def found = ((issueLinkManager.getOutwardLinks(issue.id).any{it.destinationObject.issueTypeObject.name != "Epic"}) && (issueLinkManager.getOutwardLinks(issue.id).any {it.destinationObject.statusObject.name != 'Closed'}))
return !found
What it does is to prevent issue transition to a specific Status when the linked issues other than Linked Epic has Status not Closed.
I want to include a Status called Completed in it i.e The issue can transition if the Linked issue is either in Closed or Completed Status.The other part of the validator remains the same.
How can I achieve that?
Arijit Banerjee January 18, 2016
I tried with the below code and it worked
def found = false;
if ((issueLinkManager.getOutwardLinks(issue.id).any{it.destinationObject.issueTypeObject.name != "Epic"})
          &&   (issueLinkManager.getOutwardLinks(issue.id).any {it.destinationObject.statusObject.name == 'Closed'}) )
          found = true;
 else if((issueLinkManager.getOutwardLinks(issue.id).any{it.destinationObject.issueTypeObject.name != "Epic"})
          &&   (issueLinkManager.getOutwardLinks(issue.id).any {it.destinationObject.statusObject.name == 'COMPLETED'}))
          found = true;
return found
Jeremy Gaudet
January 18, 2016
I have something similar; my script looks for outward links of type "dependency", and prevents the transition if there isn't one that is unresolved.  Your case sounds similar; I had to make certain I was looking at the status of the specific link(s) of interest, while you are checking against type and status separately, which I think could be an issue.  For example, if you have two outward links where one is an Open Epic, and the other is a Closed Whatever, your "found" condition will still be met.  I think you want:
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.link.IssueLink;
import com.atlassian.jira.issue.link.IssueLinkManager;
IssueLinkManager issueLinkManager = ComponentManager.getInstance().getIssueLinkManager();
Boolean found = false;
for (IssueLink link in issueLinkManager.getOutwardLinks(issue.id)) {
        if (link.getIssueLinkType().getName()!="Epic") {
                if(link.getDestinationObject().getStatusObject().getName() != "Closed" &&  link.getDestinationObject().getStatusObject().getName() != "Completed") {
                        found = true;
return !found;
The above code will require that all non-Epic outward links (if any) be completed/closed.  If you want just one, then use:
                if(link.getDestinationObject().getStatusObject().getName() == "Closed" ||  link.getDestinationObject().getStatusObject().getName() == "Completed") {
                        found = true;
return found;
This version will also require that there be at least one non-Epic link.
Vasiliy Zverev
January 17, 2016
Try this code:
IssueLinkManager issueLinkManager = ComponentAccessor.getIssueLinkManager();
          && (  (issueLinkManager.getOutwardLinks(issue.id).any {it.destinationObject.statusObject.name == 'Closed'})
          ||     (issueLinkManager.getOutwardLinks(issue.id).any {it.destinationObject.statusObject.name == 'Completed'}      )
return !found
This does not work.It works for first level i.e. Closed but for the second it is not validating as expected.In my linked issue there is a ticket of Status Completed which ideally should let the main ticket to go to next status but its not.
Vasiliy Zverev
January 18, 2016
Lets try to understand each other.
We have some issue and several linked issues. If one of NOT Epic issues is into Closed or Completed status this transition should be done.
Is it correct?
Consider my main issue is Release and the Release has many Defects Stories and Release Linked to it.The requirement is until all the linked issue(apart from Epic,Epic can be at any Status) are in either Completed or Closed the main Release ticket Cannot be marked to some specific Status say Closed.
Hope that Clarifies.
Can you please provide any solution?
Vasiliy Zverev
January 18, 2016
Try this one:
String[] allowedStatuses = {"closed"; "Completed"};
for(Issue curIssue: issueLinkManager.getOutwardLinks(issue.id)){
    if(curIssue.getIssueTypeObject().getName() != "Epic"){
        if( !allowedStatuses.contains(curIssue.getStatusObject().getName()))
            return false;
return true;
Arijit Banerjee January 21, 2016
As i mentioned that i tried with the below mentioned code and it worked but there seems to be an issue when there are no linked issue to the main ticket yet it is throwing exception.How can i get rid of that keeping the functionality of my code same basically it should by pass the validation when no linked issues are there.Code implemented is as below:
def found = false;
          found = true;
          found = true;
return found
Learn more
