Workflow affected issues
rajesh174u March 2, 2014
Hi All,
I change the workflow of one issue type.. but i forgot to specify the status.. but how i can revert all issues status to old one..
Could you suggest one ASAP.
Rajesh
Nic Brough -Adaptavist-
March 2, 2014
You'll need to identify all the issues in the wrong status (I'd try "status was" in the advanced search), and somehow flag them to say the status is wrong.
Once you've got that list, you'll need to check the workflow to work out how to transition them back to the right status.
Then you can use bulk-edit to transition them all into the correct status.
