I created a new project and edited the default workflow (it created a copy as expected). I added new steps and transitions, and published the workflow. The workflow and its workflow schema are active and associated with the project.
However, I am unable to see the workflow (transition) buttons on the issue view. I can click on Start Progress, Resolve, and I see Close in the workflow drop down, but not the other transitions. There is a transition from Start Progress to my new "Validate" step, and a transition from the new "Validate" step to resolved.
I've searched and searched and cannot find the answer.
Version of jira as seen from the bottom of each web page is: v5.2.11.
Brent
you need to check the conditions on those workflow actions!!
@rambanam: That is what I thought too. By "workflow actions" I believe you mean transitions?
If so, then I made sure that the transition conditions on this missing transition button matched up exactly with a transition that is showing up as a workflow button, which was the Starting Progress transition. I then attempted to verify it by adding an issue and the new button corresponding to my Validate transition is still missing.
Should I provide additional details here? What else can I try?
yes i am speaking about transitions,
can you post screen shots of workflow overview and validate transition conditions tab!!
@brent- I hope you haven't forgotten to publish the workflow after adding your new step.
@tarun: Yes I believe I did.
@rambanam: Technical glitch preventing me from posting screenshots. https://answers.atlassian.com/questions/31586/aac-itself-best-way-to-embed-photos-for-questionssays it is doable, but I do not see any web page links or anything that allows for uploading from my view.
Anyone know how to allow me to upload pictures into this answer site?
The answer is currently "no" as I understand it: The "Dec 30 '11 at 06:09 AM" answer leads me to believe that was not implemented. I'll have to find a image server to serve the pictures.
What I see after I click on the Edit button. It is strange that I have added a Validation step into the diagram, but there does not exist such a thing listed in the Statuses in the left side:
Validate(721) transition Conditions view (see left side of diagram in prior post):
@rambanam: Ok now I'm done posting images of what I believe you asked for. Any ideas of what might be amiss?
Thanks!!
Validate (721) Edit Transition View. Perhaps I need to assign a view? Is that the blocker here?
the condition says that only assignee can do transition, did you tried by assigned issue to yourself ?
if still unable to see the workflow action then try to run the "check workflow integrity checker" on Integrity Checker page, check the following doc
https://confluence.atlassian.com/display/JIRA/Using+the+Database+Integrity+Checker
Yes I created the task, assigned it to myself, and it is my user account that is attempting to do the transition. And it still fails.
I concluded that integrity checker is what I would need to run yesterday, but I tried to find the integrity checker but failed. I have hence filed a separate Answers question thread for that: https://answers.atlassian.com/questions/270057/where-is-the-integrity-checker
Same issue happened for me..workflow buttons disappeared..unable to change the ticket status
I had a similar problem this morning. Re-publishing the workflows (after re-indexing, which may have also helped) appears to have corrected the transitions.
