Whenever I transition a issue from one status to another status, I get this error:
Could not move to history step for #21255: root cause: while inserting: [GenericEntity:OSHistoryStep][owner,null][caller,jira-admin-contractor][dueDate,null][stepId,11][actionId,11][finishDate,2015-01-06 17:42:13.371][id,28822][startDate,2013-07-16 19:51:20.0][entryId,21255][status,Not Done] (SQL Exception while executing the following:INSERT INTO OS_HISTORYSTEP (ID, ENTRY_ID, STEP_ID, ACTION_ID, OWNER, START_DATE, DUE_DATE, FINISH_DATE, STATUS, CALLER) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?) (Duplicate entry '28822' for key 'PRIMARY'))
The same exception also occurs when I switch one workflowscheme to another workflowscheme for a project.
Unable to trace out this error at database level. What went wrong in database?
Hi
The cause of above issue is due to JIRA tracks workflow transition history via the OS_CURRENTSTEP and OS_HISTORYSTEP tables. Due to the sequence_value_item being reset, old ID values were re-assigned, resulting in duplicate errors.
Please refer below link for solution
Workflow+due+to+Duplicate+entry+error
or
Regards
Satyendra
Thanks Satyendra. I have seen these links. My query is when there are other objects listed in Sequence_value_item table there is no entry for OSHistoryStep in the sequence_value_item table. How Jira picks the next number from the sequence_value_item table when inserting records into OS_historystep table?
Hi Krishnan, Have you tried with the given solution on the link? Please follow the step it will solve you problem.
Thanks Satyendra. I have been working at the DB end. The xml in the jiraworkflows descriptor column has mismatched status id. when I changed those status id to the correct ones, the issue got resolved. To my surprise, there is no entry for OS_Historystep, os_historystep_prev in the sequence_value_item. Moreover this link https://docs.oracle.com/cd/E27119_01/doc.11113/e23128/databaseadministratorsguideprintable43.html helped me in understanding the OpenSymphony table relationship in jira workflows.
