Workflow transition script condition always true
Andrew Thorne
I am new to Groovy and I am trying to write a script that will not allow a transition to the closed state of the workflow if all of these conditions are true:
  • the issue type is not Epic and it is not a sub-task
  • the resolution is Done or Fixed on Dev
  • the Release Comments are empty
I am not having much success. My script always passes and I can not see why. Here is the code I have:
// Give error message if (all 3 need to be true):
// 1) Issue type is NOT epic nor sub-task
// 2) Resolution is Done or Fixed on Dev
// 3) Release Comment is empty
// Message
import com.onresolve.scriptrunner.runner.util.UserMessageUtil
// Custome fields: release comments
def releaseComments = customFieldManager.getCustomFieldObjectByName("release comments")
// Valid type?
if (issue.getIssueType() != "Epic" && ! issue.getParentId()) {
// Resolution is Done or Fixed on Dev?
if (issue.getResolution() == "Done" || issue.getResolution() == "Fixed on Dev") {
// Release comments are blank
if (issue.getCustomFieldValue(releaseComments) == "") {
UserMessageUtil.error("Release Comments required when resolution is Done or Fixed on Dev.")
return false
return true
To be honest, I am not sure I am doing this correctly so any hints or tips for my code are welcome.
FYI: we have Jira 7.3.6 and ScriptRunner 5.4.1
Andrew
Nic Brough -Adaptavist-
May 31, 2018
My guess is that your logic is broadly right, but your equivalence checks (==) are not.
For example, getIssueType() will return an issueType object, not a string, so your check for "is not epic" is always going to return true.  Similarly for resolution
A little more formally (I'm happier in Java than groovy for this), I would try:
if ("Epic".equals(issue.getIssueType().getName()) && ! issue.getParentId()) {
if ("Done".equals(issue.getResolution().getName()) || "Fixed on Dev".equals(issue.getResolution().getName())
The comments one might be ok as it is.  I'm not sure of issue.getParentId, I think that's ok too, but might be wrong.
Andrew Thorne
Hi, Nic,
Thanks for your reply. I tried your suggestions and I think I might be getting somewhere. I added these lines in as a debugging aid:
if (! "Epic".equals(issue.getIssueType().getName())) { log.error("Issue type is NOT Epic (good)") } else { log.error("Issue type is Epic (no release comments needed)")}
if (! issue.getParentId()) { log.error("Parent Id is null (good)") } else { log.error("Parent Id is not null (subtask)")}
if ("Done".equals(issue.getResolution().getName())) { log.error("Resolution is Done (good)") } else { log.error("Resolution is NOT Done (but is it Fixed on Dev?)")}
if ("Fixed on Dev".equals(issue.getResolution().getName())) { log.error("Resolution is Fixed on Dev (good)") } else { log.error("Resolution is NOT Fixed on Dev")}
if (issue.getCustomFieldValue(releaseComments) == "") { log.error("Release comments are empty") } else { log.error("Release Comments are NOT empty")}
However, it does not like this bit:
as it gives the error:
java.lang.NullPointerException: Cannot invoke method getName() on null object
 at Script133.run(Script133.groovy:17)
Now, Resolution has a default value of Done on the Resolve Issue screen, which is displayed before the script is executed. So, for me (ex-mainframe programmer), issue.getResolution() should not be null. But what do I know?
Andrew
