Workflow validator not working as expected
Srilatha Pokala
May 30, 2017 edited
I have configured a field as required in workflow validator. But i am keeps on getting below error when i submit...
Environment field is configured correctly in field configuration.
Environment is required. But it is not present on screen
Nic Brough -Adaptavist-
May 30, 2017
I am assuming that you are using a validator that checks a field has a value, and not one that checks that the data has changed during the current transition?
That may affect how we solve this problem, but the core of the problem is the same - you've demanded a field from a user but not given them the chance to enter it.
You need to have the field on the screen as well as the field configuration, so that the user can put data in it at the right time.
Srilatha Pokala
Thank you for the reply.
Environment field is actually on the screen too.
I figured the issue is because of duplicate field names.
I see field (Environment - Wiki Style Renderer) did conflict my field Environment.
I did changed my custom field from Environment to Environments and Environments shows up as mandatory and i no longer see that error on submittion
Srilatha Pokala
this seems like bug in com.googlecode.jsu.workflow.validator.FieldsRequiredValidator
This should have showed me 2 Environment fields at the first place
May 30, 2017
The add-on was written when JIRA did not allow any duplicate names.  Atlassian removed that a while ago, but are under pressure to put it back, as it's a total nightmare having fields of the same name.
Try renaming the "type" custom field, that should tell you if you have the wrong field on screen and in the validator.
