I have a draft workflow that will not publish.
I have tried to discard the draft and re-edited it. Any edits from 1 edit to 10 still will not allow me to save the draft workflow.
I tried to save a copy when publishing, and it still wont publish.
Also the draft will not allow me to create a transition from and to the same status. Not sure what is going on.
Using JIRA 6.2.4
You should check the log file for errors, it should give you a hint.
