Worklog comments are not correct.
Steven Lee August 8, 2017
I have an issue/ticket with more than 20 worklogs (around 42 worklogs including the oldest one).
Now, I sent a request to retrieve those worklogs using GET method and this URL https://xxyyzz.atlassian.net/rest/api/2/issue/<issue>/worklog
I was able to retrieve all worklogs however, I noticed that some worklogs contains incorrect comments and those comments are 'time-tracking' - all the same. I know I didn't submit a worklog with the comment. I even checked the comment from the site to confirm that those were not the comments I put.
The odd behavior started after the 22nd worklog. So, basically, the first 22 worklogs contains correct comments while the rest of the worklogs contains 'time-tracking' comments.
Question is how will I be able to retrieve the correct comments?
Is this an issue with JIRA REST API?
Adam Herman
July 16, 2018
Hello, we are running into this as well.
Was there ever a solution for this?
