Worklog report
Radu Muntean January 20, 2022 edited
I am trying to build a report to show this week logged work alone for each user. The filter I use is this:
worklogAuthor = currentUser() AND worklogDate >= startOfWeek(-1)
(startofweek(-1) just to align to a Monday to Sunday week)
The problem I have is that the query is picking up, and the dashboard is summarizing, all the hours from the item so if a user has hours logged this week but also last week they get summed together. If the user has hours logged just last week the item is disregarded as normal.
Is there any other way to do this and get the correct figures per week?
Thank you,
Radu
Community moderators have prevented the ability to post new answers.
Post a new question
Ewa Grabowska-Ptak_SolDevelo_
Hello @Radu Muntean
Have you consider trying out a marketplace app? I would like to recommend you our Worklogs Time Tracking and Reports app. This way, you can easily track your time and create a report to answer any question regarding your time logs.
For example you can create a report and view how much time and on which issue each user spent during a week, month or any other period of time:
Or check how much time was spent on specific issue type, priority, epic or any other custom Jira issue field that you might have.
Worklogs are using Time Logs which is Jira's native function to create a report from it. So, you can install a free trial and create your report at once from the Time Logs that you already have. Check it out here!
