by default all the possible reporting on XRAY is build on reporting execution status at the test case level.
This is the case for any widgets we use in dashboards, as well as any reports we see.
However in our case, we are having very long test cases, taking time to execute.
Therefore we would like to manage the team based on test step level and test execution progress at the test steps.
What are the possibilities/options to do this?
Are there realtime dashboards/widgets we can use?
What reports can we build or are available?
Hi @Glenn Quirynen ,
Xray doesn't provide reports for test steps.
The only thing you can do so far is to include the TestRun Progress as a column in the panel where test runs are shown, in the Test Execution issue screen.
