XRAY Reports: Requirement Coverage & Traceability Report not generated
Pooja July 9, 2019 edited
Currently doing a POC for XRAY with Cucumber Test Framework Integration
  1. Created Test, Test Set, Test Plan and User Story.
  2. Added multiple Tests to TestSet, Test Plan , User Story (Is Tested By) through REST API
  3. Executed the Cucumber Tests and uploaded the Test Execution results using REST API
All the above steps worked fine.
For Xray Reports:  when trying to generate Requirement Coverage & Traceability Report - no data is Returned.
See following screenshots :TraceabilityReport.JPG
However Test Plan Report is generated Successfully
See Screenshot :
Christopher Jaksch
July 10, 2019
Hi @Pooja
did you enable the Xray Requirement Coverage for your JIRA project already?
https://confluence.xpand-it.com/display/public/XRAY/Quick+Setup#QuickSetup-EnableXrayinyourprojects
Best wishes
Chris
STAGIL
Pooja July 10, 2019 edited
Hi @Christopher Jaksch ,
Yes it has been enabled.
However in the issue type mapping, I see "Requirement Issue Types" has not been mapped as per: https://confluence.xpand-it.com/display/public/XRAY/Issue+Type+Mapping
Can you advise if this is an issue ? Does "Requirement Issue Types" need to be created to generate the report ?
Pooja
Pooja July 10, 2019
This issue is now resolved.
The problem was with IssueType Mapping being incorrect.
Fixed the Issue Mapping as per: https://confluence.xpand-it.com/display/public/XRAY/Issue+Type+Mapping
And the Reports now work.
Thanks.
Christopher Jaksch
July 11, 2019
Good job, Pooja!
Jhon Alejandro Betancourt Contreras
August 26, 2024
Yo tengo el mismo problema y dejan links de confluence que no sirven y estan caidos
Anastasia Gourina March 15, 2023
Hey there,
I am having a smilier problem. I have checked the coverage fields etc.
There are meant to be 724 results returned using a JQL. But when the traceability report is generated we get "No requirements found." Have done everything I could to trouble shoot this. Note we are using the cloud version.
