we need feature files per story. If we activate the Xray requirement coverage in the project settings, then the features per epic will be bundled in only one feature file. If requirement coverage is deactivated, we get the feature files per story, but reports are no longer possible. How can we achieve both - feature files per story and requirement coverage?
Best regards
Edit: Solved - Epic-story relation under issue-type-mapping deactivated
Hi :)
As stated in your inquiry, the solution for that is "Epic-story relation under issue-type-mapping deactivated". If that option is disabled, that can be achieved.
Best Regards,
Team Xray
Help us plant more trees
