Xporter - Is it possible to access all values of a select field to export them?
Frank Weismantel January 7, 2015
Pedro Rodrigues January 8, 2015
Hi Frank,
As you can check on the Xporter for JIRA Documentation, here, Select List custom fields are supported by the plugin. But the Xporter for JIRA plugin only exports the contents of fields that are filled/selected, and the only exported values of a select field are the ones that are in use, so it isn't possible to export all the available values of a select field.
Best Regards,
PMRodrigues
