Xray Documenting Or Constraining Change of Test Execution Status
C_ Bönitz May 12, 2023 edited
Hello!
Once we have the freedom to change the status of a test execution, I am trying to understand the following:
1. If this change can be limited to some Jira users or if anyone can change this anytime;
2. If I can see that someone changed it, if yes who and when. In the secction "Changes" of the Ticket I dont see any register after I change something. This could be a real problem in my opinion.
I couldn't find any information about this in the documentation or here in the forum.
Stefan Salzl
Hi @C_ Bönitz
Test executions are equal as native jira issues. Therefore they can have an own workflow. Within the workflow it can be specified who is allowed to do a specific transition (either a specific user, user group or project role). Please contact your Jira admin who is responsible and has the permission to edit workflows.
regarding your 2. question:
As mentioned before this is a jira native workflow action and any change of a workflow status can be seen in the issue. I don´t know exactly what is meant with the "changes" section but there is a section at the very bottom of each issue called "Activity" where you will find all information/comments/transitions/changes regarding your issue (see screenshot):
Best
Stefan
C_ Bönitz June 14, 2023
Thank you so much Stefan! Totally clarifying.
Like Stefan Salzl likes this
Stefan Salzl
@C_ Bönitz
awesome 🙌🏼 thanks for your feedback.
Would xou please consider to click the accept button in order to mark this question as solved. This will make it easier for other users to find solution in case they are faced with similar problems.
Best
Stefan
Learn more
