You dont have permission to create issue
Neeta Dubey
One of our client user is unable to create ticket although permission helper shows that he is active user and have permission to create issue. Attached are the screen shot. Please assist.
Nic Brough -Adaptavist-
September 21, 2015
What is the actual error you get?  Can they start creating the issue, or does it just not offer them the project they're trying to create it in?
Neeta Dubey
Hi Nic, You don't have the correct permissions - user (15004893 ) not found. Although when I check in permission helper it does show that this user have creat issue. I've also explicitly given create issue permission to this user. Any help would be appreciated.
September 25, 2015
Ok. But when do they get the error?
Neeta Dubey
When they login. Enter ticket details like summary, description etc and hit the create button at the bottom.
September 25, 2015
So not when they log in, but when they try to create an issue. Do you have any validators or post-functions on the "create" transition?
Neeta Dubey
I dont have explicit validator which will prevent them from creating ticket. Rest all user are to create issue.
September 25, 2015
Not quite what I asked. Do you have ANY validators? Or post-functions?
Neeta Dubey
Yes i've create issue permission validator.
September 25, 2015
And what does it say exactly? And are there others? And what post-functions to you have?
vickey palzor lepcha September 25, 2015
may be project specific problems ?
Neeta Dubey
I'm attaching validator and post function screen shot. just to rephrase the issue. Only two client user are unable to create ticket. rest client user can create it fine.
Neeta Dubey
Neeta Dubey
September 25, 2015
Ok, good, not the validators then. You need to run four tests now: 1. With both added post-functions in place (We already know this fails, but I wanted to mention it for completeness) 2. With the "assign" post-function, but not the "set security level" 3. With the "set security level" post-function, but not the "assign" 4. With both "assign" post-function and "set security level" removed.
