Zendesk External ID to JIRA Field
Josh loe
March 27, 2019
Is there a way to sync the Zendesk External ID to a field in JIRA?
Maarten Cautreels
March 27, 2019
Hi Josh,
I'm not sure if this can be synced using the default Zendesk for Jira plugin. But as I mentioned in an answer to your other post on the community it should definitely be possible using Exalate.
Best,
Maarten
Tebi Costamagna
March 10, 2021
Hi Maarten,
Do you have any idea if it is currently possible to sync the Zendesk External ID to a field in JIRA without using an exalate?
Register now
