I'm trying to add Jira test cases into zephyr cycle and first test case has been created twice instead of one time. I am using the following zephyr REST API to add test to cycle.
https://getzephyr.docs.apiary.io/#reference/executionresource/add-tests-to-cycle/add-test's-to-cycle
Here is the sample request body:
POST - https://<doamin>/rest/zapi/latest/execution/addTestsToCycle/
Basic Authentication - xxx
Content-Type - application/json
"versionId":xxx,
"method":"1",
"cycleId":xxx,
"issues":["ISSUE-001","ISSUE-002","ISSUE-003","ISSUE-004",
"ISSUE-005","ISSUE-006","ISSUE-007"],
"projectId":xxx,
"folderId":xxx
For example first test case (ISSUE-001) has been added twice into cycle instead of one time and other test cases added only one time. Please help me on this to fix the issue.
Thanks in advance!
Hello Ashok,
I am not sure what can be causing this issue.
Can you submit a support ticket so that our team can take a closer look?
https://support.smartbear.com/message/?prod=zephyr
Hello Steven,
Thanks for your prompt response. :)
I have created a support ticket for the same and below are the details.
Support Portal: https://support.smartbear.com/message/?prod=zephyr
Support Ticket # - 00413965
