able to Replace None with any other text even when the custom field is not mandatory.
Priyanka Khare
Can NONE be replaced with "do not apply" in the JIRA custom field . I dont mean to make the field or mandatory. My concern is to be able to Replace None with any other text even when the custom field is not mandatory.
Thomas Deiler
Dear @Priyanka Khare,
unfortunately not. The "None" is the corresponding value for NULL (in the Database). Atlassian itself can only rename this default like behavior.
Best, you create an option "do not apply" and make it to the default value.
So long
Thomas
Thomas Deiler
was my answer fine enough to be accepted?
Many Thanks
Thomas
Register now
