Hi
we are using jira 7.3.3 and we are in a process of upgradation . so we created a clone of dev in different sever and working on that. but accidentally application-data folder is deleted that is home directory of jira. i tried replaceing it with application-data folder from dev environment but its showing error . instance cannot be recovered.
I am attaching catalina logs when we start jira started. Please help me with this.
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.tomcat.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : /opt/atlassian/jira/7.3.3/jre/lib/amd64
sun.cpu.endian : little
sun.cpu.isalist :
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : UTF-8
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level : unknown
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.StandardJarScanFilter.jarsToScan : log4j-web*.jar,
log4j-taglib*.jar,
log4javascript*.jar,
slf4j-taglib*.jar
tomcat.util.scan.StandardJarScanFilter.jarsToSkip : bootstrap.jar,
commons-daemon.jar,
tomcat-juli.jar,
annotations-api.jar,
el-api.jar,
jsp-api.jar,
servlet-api.jar,
websocket-api.jar,
jaspic-api.jar,
catalina.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-storeconfig.jar,
catalina-tribes.jar,
jasper.jar,
jasper-el.jar,
ecj-*.jar,
tomcat-api.jar,
tomcat-util.jar,
tomcat-util-scan.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-jni.jar,
tomcat-websocket.jar,
tomcat-i18n-en.jar,
tomcat-i18n-es.jar,
tomcat-i18n-fr.jar,
tomcat-i18n-ja.jar,
tomcat-juli-adapters.jar,
catalina-jmx-remote.jar,
catalina-ws.jar,
tomcat-jdbc.jar,
tools.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
jstl.jar,
taglibs-standard-spec-*.jar,
geronimo-spec-jaxrpc*.jar,
wsdl4j*.jar,
ant.jar,
ant-junit*.jar,
aspectj*.jar,
jmx.jar,
h2*.jar,
hibernate*.jar,
httpclient*.jar,
jmx-tools.jar,
jta*.jar,
log4j*.jar,
mail*.jar,
slf4j*.jar,
xercesImpl.jar,
xmlParserAPIs.jar,
xml-apis.jar,
junit.jar,
junit-*.jar,
hamcrest-*.jar,
easymock-*.jar,
cglib-*.jar,
objenesis-*.jar,
ant-launcher.jar,
cobertura-*.jar,
asm-*.jar,
dom4j-*.jar,
icu4j-*.jar,
jaxen-*.jar,
jdom-*.jar,
jetty-*.jar,
oro-*.jar,
servlet-api-*.jar,
tagsoup-*.jar,
xmlParserAPIs-*.jar,
xom-*.jar
user.country : US
user.dir : /opt/atlassian/jira/7.3.3/bin
user.home : /home/jcadmin
user.language : en
user.name : jcadmin
user.timezone : America/New_York
2018-11-28 15:58:43,418 JIRA-Bootstrap INFO [c.a.j.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from /var/atlassian/application-data/jira/7.3.3/dbconfig.xml
28-Nov-2018 15:58:43.488 INFO [main] org.apache.coyote.AbstractProtocol.start Starting ProtocolHandler [https-jsse-nio-8443]
2018-11-28 15:58:43,686 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2018-11-28 15:58:43,687 JIRA-Bootstrap INFO [c.a.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
28-Nov-2018 15:58:43.805 INFO [main] org.apache.tomcat.util.net.NioSelectorPool.getSharedSelector Using a shared selector for servlet write/read
28-Nov-2018 15:58:43.823 INFO [main] org.apache.catalina.startup.Catalina.start Server startup in 6490 ms
2018-11-28 15:58:44,920 JIRA-Bootstrap ERROR [c.a.jira.startup.LauncherContextListener] Unable to start JIRA.
com.google.common.util.concurrent.UncheckedExecutionException: java.lang.RuntimeException: Unable to obtain a connection from the underlying connection pool
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2203)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
at com.google.common.cache.LocalCache$LocalLoadingCache.getUnchecked(LocalCache.java:4830)
at org.ofbiz.core.entity.GenericDelegator.getGenericDelegator(GenericDelegator.java:107)
at com.atlassian.core.ofbiz.CoreFactory.getGenericDelegator(CoreFactory.java:34)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.configureOfbiz(DatabaseConfigurationManagerImpl.java:215)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:295)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseConfigured(DatabaseConfigurationManagerImpl.java:199)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:134)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$start$0(DefaultJiraLauncher.java:103)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:31)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:101)
at com.atlassian.jira.startup.LauncherContextListener.initSlowStuff(LauncherContextListener.java:149)
at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.RuntimeException: Unable to obtain a connection from the underlying connection pool
at org.ofbiz.core.entity.jdbc.interceptors.connection.ConnectionTracker.trackConnection(ConnectionTracker.java:60)
at org.ofbiz.core.entity.transaction.JNDIFactory.trackConnection(JNDIFactory.java:253)
at org.ofbiz.core.entity.transaction.JNDIFactory.getJndiConnection(JNDIFactory.java:224)
at org.ofbiz.core.entity.transaction.JNDIFactory.getConnection(JNDIFactory.java:147)
at org.ofbiz.core.entity.TransactionFactory.getConnection(TransactionFactory.java:136)
at org.ofbiz.core.entity.ConnectionFactory$1.getConnection(ConnectionFactory.java:52)
at org.ofbiz.core.entity.jdbc.DatabaseUtil.getConnection(DatabaseUtil.java:133)
at org.ofbiz.core.entity.jdbc.DatabaseUtil.getTableNames(DatabaseUtil.java:904)
at org.ofbiz.core.entity.jdbc.DatabaseUtil.checkDb(DatabaseUtil.java:167)
at org.ofbiz.core.entity.jdbc.DatabaseUtil.checkDb(DatabaseUtil.java:145)
at org.ofbiz.core.entity.GenericDAO.checkDb(GenericDAO.java:1475)
at org.ofbiz.core.entity.GenericHelperDAO.checkDataSource(GenericHelperDAO.java:270)
at org.ofbiz.core.entity.GenericDelegator.initialiseAndCheckDatabase(GenericDelegator.java:238)
at org.ofbiz.core.entity.GenericDelegator.<init>(GenericDelegator.java:169)
at org.ofbiz.core.entity.GenericDelegator$1.load(GenericDelegator.java:93)
at org.ofbiz.core.entity.GenericDelegator$1.load(GenericDelegator.java:90)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
... 15 more
Caused by: java.sql.SQLException: Cannot create PoolableConnectionFactory (ORA-28000: the account is locked
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2303)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createDataSource(BasicDataSource.java:2043)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.getConnection(BasicDataSource.java:1543)
at org.ofbiz.core.entity.transaction.JNDIFactory$2.call(JNDIFactory.java:257)
at org.ofbiz.core.entity.jdbc.interceptors.connection.ConnectionTracker.trackConnection(ConnectionTracker.java:54)
... 35 more
Caused by: java.sql.SQLException: ORA-28000: the account is locked
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:392)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:385)
at oracle.jdbc.driver.T4CTTIfun.processError(T4CTTIfun.java:938)
at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:655)
at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:416)
at oracle.jdbc.driver.T4CTTIoauthenticate.doOAUTH(T4CTTIoauthenticate.java:825)
at oracle.jdbc.driver.T4CConnection.logon(T4CConnection.java:596)
at oracle.jdbc.driver.PhysicalConnection.<init>(PhysicalConnection.java:715)
at oracle.jdbc.driver.T4CConnection.<init>(T4CConnection.java:385)
at oracle.jdbc.driver.T4CDriverExtension.getConnection(T4CDriverExtension.java:30)
at oracle.jdbc.driver.OracleDriver.connect(OracleDriver.java:564)
at org.apache.tomcat.dbcp.dbcp2.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.tomcat.dbcp.dbcp2.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:257)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.validateConnectionFactory(BasicDataSource.java:2313)
at org.apache.tomcat.dbcp.dbcp2.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:2299)
... 40 more
2018-11-28 15:58:44,932 JIRA-Bootstrap INFO [c.a.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 460 MiB. Committed: 1406 MiB. Max: 10202 MiB
Non-heap memory : Used: 47 MiB. Committed: 49 MiB. Max: 1264 MiB
TOTAL : Used: 507 MiB. Committed: 1455 MiB. Max: 11466 MiB
But what about the standard backups you should be taking regularly?
As a side note, I install version 8.2.3 today and my atlassian-data folder disappeared!
It now gets moved to /var/atlassian/atlassian-data
I was pretty surprised to not see the folder anymore as I was looking for the backup folder...
before the files are missing we are not ready for upgrade. we just started to reach the space for backup . so no backup is taken . when i copy the file var/attlasian/aplication from dev and replaced before its not showing jira in browser but not its not allowing me to login to the accout.
That makes it more difficult again, but it is possible to recover a complete Jira from a backup of the database and a copy of the attachments. Do you have those? (Database backup literally means a backup of the data, using the db tools to do it, not the xml copy)
ok i dont have any backup all export folder is also deleted .
I'm afraid you have destroyed your installation. Just copying bits from other installations is not going to be good enough.
Your best option is to install a new clean copy of Jira, of exactly the same version, then import the data from the backup you took at the beginning of the process.
Register today
