add a comment while changing issue status by REST
Ziyan Liu
I am trying to add a comment while changing issue status by rest api.
curl -D- -u admin:admin -X POST --data @/Users/ziyan/Desktop/test.json -H "Content-Type: application/json" https://mytestingurl.atlassian.net/rest/api/2/issue/ZD-25/transitions?expand=transitions.fields
Here is the JSON:
    "transition": {
        "id": "61"
    "update": {
        "comment": [
                "add": {
                    "body": "Bug has been fixed."
For some reason, I get the 204 response and have my status changed, but I am unable to add the comment. What could possibly go wrong?
Please help! Thanks
Brant Schroeder
I believe that you just have the order wrong.  Try this and it should work:
JSON:
    "update": {
        "comment": [
                "add": {
                    "body": "Comment added when transitioning issue"
    "transition": {
        "id": "61"
Ziyan Liu
That doesn't change anything :(
Brant Schroeder
Is the comment posting if you remove the transition?
Ziyan Liu
I figured out the answer. You can only add a comment while transitioning by REST if you require a comment for transitioning in UI. Thanks for your help Brant.
Like 8 people like this
vigneshyadhan
December 29, 2021
how can we done the same for rest/api/3?
Ankit Rastogi
@Ziyan Liu  @Brant Schroeder  Can you please give me json for the transitions which can add comment. I am getting stuck on same this issue
Rafael Costa
July 12, 2022
@Ziyan Liu
"update": {
"comment":[{
"add": {
"body": "your comment"
"transition": {
"id": "331"
but as @Ziyan Liu said, you need a screen with a comment field on the transition. to do it only create a screen empty, without fields.
Register here ⬇️
