add an additional custom field if a certain component is chosen in the create screen
p.noack@samsung.com March 12, 2019
I was wondering if there is some means of adding a new field to the create screen if a certain component is chosen?  Currently components are mandatory.  Ideally if someone chose the RMA component I would like a Jeditor Template to appear and become a required field on the create screen.
Has anyone tried something like this?  Jeditor looks like an easy solution for the template part of things but maybe scriptrunner would have a more complete solution.
Tinker Fadoua
p.noack@samsung.com
Do you mean Dynamic Fields?
For example you select a Component the next field displays options related to the component selected.
Let me know if that's what you are trying to achieve.
Best,
Fadoua
Yes that is what I am trying to achieve but the dynamic Field would be a template.
Tinker Fadoua
Tinker Fadoua
If satisfied with the help provided please don't forget to Accept my Answer p.noack@samsung.com 🖐
p.noack@samsung.com March 13, 2019
Let me dig into this a bit.  I have this plugin and I am using it.  I have not seen how you can choose a component and then have one of these dynamic forms appear.  Let me Read the docs and see if that is possible.
Tinker Fadoua
p.noack@samsung.com  I am using it at work it is working perfect. On the plugin homepage you can see on the left side dynamic fields.
Best,
Fadoua
p.noack@samsung.com March 19, 2019
I checked with the vendor and they do not support a component as being the master cell of dynamic fields.  It is on their roadmap however.
I finally caved and just made a new issue type.  I created a template for the description field using the Jeditor template feature and that seems to be working well now.
Tinker Fadoua
p.noack@samsung.com  ok I see you want a whole template vs a custom field.
Best of luck!
Fadoua
Learn more
