add days to date by behaviour or script runner
A November 3, 2015
Requriement
1) Add 10 days to custom date field.
2) 10 days will be pulled from a custom field ( number)
Tried
Below step using behavior plugin but not working
import static com.atlassian.jira.issue.IssueFieldConstants.*
def desc = getFieldById("customfield_11002")
def defaultValue = getFieldById("customfield_11003")
def newvalue = defaultValue.getFormValue() as Long
desc.setFormValue(newvalue)
return
I am not able to access the value of customfield_11003 to store in customfield_11002
 Not interested in using misc custom fields as it is messing up with my custom field view
4 votes
Thanos Batagiannis [Adaptavist]
November 4, 2015
Hi Armar,
For the searcher use the Date Time Range picker. For the template use Date Time Picker.
And in the inline field add the logic. In your case should be something like:
def dateField = getCustomFieldValue("DateCF")
def numberField = getCustomFieldValue("NumberCF")
def number = numberField?.intValue()
if (number == null || dateField == null)
    return
def result = dateField + number
return new Date(result.getTime())
Please let me know if this works for you.
Thanos
November 4, 2015
Amar, As I said, the solution I propose is to use scripted field (https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html) and not a behaviour. As far as I understand you want a custom field which will hold the value of two other custom fields (in your case a date plus a number).
A November 4, 2015
ok... do i need to import any headers
November 4, 2015
You don't have to import anything in the above script.
A November 4, 2015
/sr/jira.issueviews:searchrequest-xml/temp/SearchRequest.xml [onresolve.scriptrunner.customfield.GroovyCustomField] getCustomFieldValue called from script: No field with ID or name customfield_10620 /sr/jira.issueviews:searchrequest-xml/temp/SearchRequest.xml [onresolve.scriptrunner.customfield.GroovyCustomField] getCustomFieldValue called from script: No field with ID or name customfield_11106
November 4, 2015
Apparently there are no custom fields assigned to you project with such names. Please try to add as a param in getCustomFieldValue the name and no the id of the custom field.
A November 4, 2015
you mean def dateField = getCustomFieldValue("Planned date") def numberField = getCustomFieldValue("Number of days") def number = numberField?.intValue() if (!number || !dateField) return def result = dateField + number return new Date(result.getTime()) instead of def dateField = getCustomFieldValue("customfield_11111") def numberField = getCustomFieldValue("customfield_11234") def number = numberField?.intValue() if (!number || !dateField) return def result = dateField + number return new Date(result.getTime())
A November 4, 2015
IT works!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :-)
A November 4, 2015
Now how can i skip the weekend days.. I mean considering only working days.
November 4, 2015
I suppose the logic should be something like that (in pseudocode): while (i < number) { dateField ++ if (dateField == sunday || dateField == saturday) i -- i ++ }
A November 4, 2015
Thank will work on it... thanks alot for quick reply and complete solution
A November 5, 2015
Hi Thanus. /*import com.atlassian.jira.issue.MutableIssue import java.sql.Timestamp; MutableIssue myIssue = issue; def dateField = getCustomfieldValue("Date") Calendar dateField = Calendar.getInstance() def numberfield = getcustomFieldValue("Days") def number = numberfield?.intValue() if number (!number || !dateField) return dateField.add(Calendar.DATE, number) while ([Calendar.SATURDAY, Calendar.SUNDAY].contains(dateField.get(Calendar.DAY_OF_WEEK))) { def dateField.add(Calendar.DATE,number) } def result = new Timestamp(dateField.gettime()) return new Date(result.gettime())*/ Not working
amar November 3, 2015
Thanos, Is it possible to add the date and number and get a output.. If yes please let me know which import option I need to choose Regards Amar
November 3, 2015
Amar, You can have a look at https://scriptrunner.adaptavist.com/latest/jira/scripted-fields.html I think a scripted field that depends on the result of 2 other custom fields is what you want. Please let me know if you need any help with the script part Cheers Thanos
A November 3, 2015
Hi Thanos, I want to use 1 custom date field value and add it with 2nd custom number field content and populate result into 3rd custom field
November 3, 2015
Hi Amar, Could you please be more specific in what you are trying to achieve, maybe using a scripted field (if you are using script runner) ? What type are your custom fields ?
Junaid Shah
November 3, 2015
Have you tried using the JIRA Workflow Toolbox plugin and using the Post Function Math & Date-Time Expression Calculator
I think that will do exactly what you are looking for.
In the Post Function you can use something like
datePart({Customfield_ID(Date)}, LOCAL) + ({CustomField_ID(Number)} * {DAY})
A November 3, 2015
Hi Sy, Thanks for the quick reply. I want the instance update, not transition based update
