add multiple users to a group in JIRA?
sn
hi ,
we use JIRA 6.4 + AGILE server and we want to add multiple users to a group. our user gropus flows from JIRA to conflunce. we want to add around 60 users to a group.
is there a way to do it through CSV. we dont use AD and our groups are in AD.
thanks !
somethingblue
June 13, 2017
Hi Shilpini,
One possiblity is to do this through CROWD.  The Importing Users from CSV Files knowledge base has an example user CSV file and an example group membership CSV file that you can reference.
If you are not using CROWD, you can find out how to integrate it with JIRA using the Integrating Crowd with Atlassian JIRA knowledge base article.
Hopefully that helps you get started!
Branden
Register today
