×Hi @marshal ,
Add a new custom field Message Custom Field (for view) and on the description place the following code:
{panel:bgColor=#deebff}
(i) This info panel
{panel}
Add the above field on the appropriate screens and adjust its order. That should do the trick.
Let me know if everything works!
Alex
Hi Alex,
Thanks for your reply, seems like i need add new app as below, do you know if we don't rely on new app, how should we do this?
can not search about mesxxxxxxx
app
It seems that you haven't install that app yet, and that's why you can't find it while searching. Try to install it first.
This works for us in Jira Data Center 8.13 to produce a big yellow box
<div style="background-color: yellow; border: 2px solid red; margin: 4px; padding: 2px; font-weight: bold; font-size: larger;">
Some text goes here
</div>
It looks like you want something that looks like a Confluence "info" macro. I would create one in a wiki page then use Inspect to find the actual div element attributes
My issue also related to Message Custom field (for edit) type and i'm unable to get color background to my message here my question below.
Please advice me where I did mistake in my configuration and thanks in advance.
Siva.
@Daniel Ebers directed me to this thread from my post. This worked for me in Jira Cloud without adding any apps.
But this is about jira server ;)
