Both of the scripts having same logs.warn, the only difference is one is with literal values and other having parameterized values from custom fields but Unable to add actor to project in the right side of the script, Leftside scripts works fine however right side with errors:
Error Says:
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.bc.projectroles.DefaultProjectRoleService.addActorsToProjectRole() is applicable for argument types: (ArrayList, com.atlassian.jira.security.roles.ProjectRoleImpl, String...) values: [[smansoor], Contributor, Project: MQM, atlassian-user-role-actor, ...] Possible solutions: addActorsToProjectRole(java.util.Collection, com.atlassian.jira.security.roles.ProjectRole, com.atlassian.jira.project.Project, java.lang.String, com.atlassian.jira.util.ErrorCollection), addActorsToProjectRole(com.atlassian.jira.user.ApplicationUser, java.util.Collection, com.atlassian.jira.security.roles.ProjectRole, com.atlassian.jira.project.Project, java.lang.String, com.atlassian.jira.util.ErrorCollection) at Script601.run(Script601.groovy:50) ~[?:?]
Can someone identify the root cause, is it because the parameter or project in addActorsToProjectRole method is type of project?
Note: ("Jirakey" is an attribute of an asset object with type: Project & 14805 is insight customfield whose scope contains this asset object)
If you paste your full script it might help.
But from what I can see the main difference might be that in one, you use the project object and the other, the project key.
Convert your project key to a project object and see how it goes. Remove "toString()" at the end of line 38
