Do you already have this field CC created in JIRA ?
If not, you can add a new multi user picker field in JIRA and ensure it is present in the create screen of the request.
You can then add the field on the customer portal refer https://confluence.atlassian.com/servicedesk024/create-your-service-desk-request-types-753402507.html
Once it is added on the portal you will need to add this field in the notification scheme to all the needed events.
wow its working but how can i activate the search form option and how can I restrict the only end users to be visible their
Sorry , I am unable to understand, can you please elaborate or use simple terms :)
for service desk side there is a additional popup option to search users (separate search form) .
but i couldn't see that in customer portal .
is there any possibilities to activate that
