adding tempo fields to jira workflow screen?
neil1967
Running jira 4.4.4 with tempo 6.5. Is there a way to add tempo fields to a workflow screen, particularly Hours and Billed Hours. I see that in later versions of tempo and jira, there is a custom field for Tempo Account, but even here, I'm not sure what this custom field contains.
Essentially, I'd like to force the entry for Tempo hours from users executing transitions in the jira workflow and don't know if there is a way.
Viðar Svansson [Tempo]
July 15, 2013
You need to add "Timetracking" field to the JIRA Screen. This is actually not Tempo specific but you should get the same results.
See: https://confluence.atlassian.com/display/JIRA/Defining+a+Screen#DefiningaScreen-timetracking
Viðar
Register today
