assign to a user in field if exsting
Jessy Li March 10, 2016
Hello, I have a field called-Solution provider and I want to write up a script in post transition
if (solution provider != null)
	assign to solution provider
can someone share how to do it?
Vasiliy Zverev
March 10, 2016
Here is a code example
CustomField customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Сложность")
if(customField != null)
    issue.setAssignee(customField.getValue(issue))
There is not update issue funciton since there is special step for it into post function list.
Jessy Li March 15, 2016
Hello, Vasiliy,
Can you help me with this issue?
I got error message from log:
2016-03-15 22:15:57,585 http-bio-8443-exec-10547 ERROR jessy_li 1335x2042069x2 1748upc 10.1.75.160 /secure/WorkflowUIDispatcher.jspa [scriptrunner.jira.workflow.ScriptWorkflowFunction] Script function failed on issue: TCD-155, actionId: 11, file: <inline script>
groovy.lang.MissingMethodException: No signature of method: com.atlassian.jira.issue.IssueImpl.setAssignee() is applicable for argument types: (com.atlassian.jira.user.DelegatingApplicationUser) values: [jason_tong(jason_tonger)]
Possible solutions: setAssignee(com.atlassian.crowd.embedded.api.User), getAssignee(), setAssigneeId(java.lang.String), getAssigneeId()
at Script21.run(Script21.groovy:7)
Vasiliy Zverev
March 15, 2016
Try this one:
import com.atlassian.jira.component.ComponentAccessor
    issue.setAssigneeId(customField.getValue(issue))
