Sign up Log in
atlas-mvn eclipse:eclipse issue with the JDK
JPB
Hi everyone, I'm new with all of this, this is my first question here in the site.
I was working with the java JDK 1.6, but I changet it to the 1.7 version (cause the application in the company is workinh under this one).
The issue is when I apply the atlas-mvn eclipse:eclipse command, I get this:
[WARNING] Workspace defines a VM that does not contain a valid jre/lib/rt.jar: C:\Program Files\Java\jre7
[INFO] Adding default classpath container: org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.
StandardVMType/JavaSE-1.6
I changed the path to the 1.7 directory, then in eclipse added the jdk1.7 to the installled JREs. But that message is always shown, and the project is build under version 1.6.
In the project explorer in eclipse, I see this include: JRE System Library [JavaSE-1.6] for all the new projects, and the ones that I applied that comman (atlas-mvn eclipse:eclipse). So, the system is not recongnizing the change to 1.7?
Someone can help me with this, thank you!!
P.D: I have tried deleting the buildpath, configuring it, changing to 1.7 in the project properties, but none of those have worked.
rambabu patina
May 13, 2014
Hi Jhonnatan,
Please change the --vm entry in the eclipse.ini file. To change follow the steps,
Navigate to the root of the Eclipse installation --> Take backup of the eclipse.ini file --> Edit the eclipse.ini file with your favorite text editor --> Add a -vm entry to file before any -vmargs entry with your latest java path
File will be looking like below:
-startup
plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_1.1.100.v20110502
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vm
C:/Program Files/Java/jdk1.7.0_32/bin
-vmargs
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
Patina
JPB
That didn t work either. The command atlas-mvn eclipse:eclipse is always adding the classpath:
bug.ui.launcher.StandardVMType/JavaSE-1.6
rambabu patina
May 13, 2014
Try to add JRE Library to the project by
Right click on your project --> Click on the Build Path --> click on the add Libraries. -->
Then Choose JRE System Library --> See weather it is pointed to Workspace default JRE(jdk1.7.0_xx) if else add the jdk 1.7 JRE library there.
Click finish and then go back to your project. Run the eclipse:eclipse command.
Patina
JPB
Right now, I have in the system library check the option:
-Workspace default JRE (jdk1.7.0_55)
Cause I changed it.
Before, I had check Execution environment with the option
JavaSE-1.7 (jdk1.7.0_55) selected.
But none of those worked, whe using the atlas command, the library is always changed to 1.6.
Thanks anyway ;)
Deleted user May 13, 2014
If you are using Windows maybe you can try updating the JAVA_HOME system variable and make it point to your Java 1.7 JDK?
JPB
I already did that, that was not the problem, but thanks.
Register Now
Upcoming Jira Events
