I am trying to work out an issue with email templates, using a local dev server started with atlas-run. I added a <jvmArgs> element in the jira-maven-plugin configuration section in my pom:
<plugin>
<groupId>com.atlassian.maven.plugins</groupId>
<artifactId>jira-maven-plugin</artifactId>
<version>${amps.version}</version>
<extensions>true</extensions>
<configuration>
<jvmArgs>-Datlassian.mail.senddisabled=false</jvmArgs>
<productVersion>${jira.version}</productVersion>
<productDataVersion>${jira.version}</productDataVersion>
</configuration>
</plugin>
I configured the email server as usual and sent a test mail both from the SMTP configuration pane and from the admin panel. So I know that the outgoing server is configured correctly, and it is capable of sending email.
However, notifications emails are not actually getting sent. As far as I can see, they are not even getting queued. The notification scheme is the default, so when I create or comment on an issue, notifications should get sent.
Is there something else preventing notifications, some other configuration I should set?
Notification helper shows green across the board; notifications really should be going out!
