atlassian products use of PKI CERTS or CAC enabled?
Chag
October 7, 2014
i tried to research this more and found that you need to create a java authenticator? or has someone succesfully been able to develop this and be able to use it to enable log-in with certs or CAC? looking to see if there is a free plug-in or code that i can fork over. Just have a customer that wants this and looking at the options of what i can do.
Bharath Venkatesh July 17, 2017
Have you tried the CAC/PIV single sign-on authenticator for Atlassian suite? It's secure and provides smart card access control to Atlassian products.
Nic Brough -Adaptavist-
October 7, 2014
I've done a basic implementation of this for a client - x509 certificates were in use.  Like you, I had to build a java authenticator for JIRA and Confluence.
The main problem I had was not the code, but that the certificates they wanted to use were fine for authorisation (you have a certificate, yup, we'll let you get to JIRA) but did not contain enough information to uniquely and strongly identify a user.
The actual code handling the cert was only really a few lines long (it picked up the cert from the header Apache passed on to it, did a bit of parsing, and then did the identity scan based on the cert details)
Chag
October 7, 2014
is this something that you public available or is more company private? im not really a developer so was trying to find if someone had code they can share and have someone in my team try to look at it. I know im asking for much but was jw.
Help us plant more trees
