automantion script update multi select list with variable
Tobbe August 17, 2023
Hi
In an automation triggered on issue linked I want to copy the linked issue to another multi issue picker field.
The code for updating a multiselect is
Issues.getByKey('ABC-1').update {
    setCustomFieldValue('Multi Select List', 'A', 'B')
but how do I repalce A,B with a variable?
If I use
def myissues = "'abc-123','abc-345'"
setCustomFieldValue('Multi Select List', myissues)
then I get an error because it takes 'abc-123','abc-345' as one single issue and not 2 comma seperated.
Hi @Tobbe
Since this is multiple options from a Multi-Select List, have you tried adding the options in a list like:-
def myissues = ['abc-123','abc-345']
Give it a go and see how it is. :-)
I am looking forward to your feedback.
Thank you and Kind regards,
Ram
Hi Ram. That doesnt work either. It cant take an array list
ArrayList cannot be cast to class com.atlassian.jira.issue.Issue (java.util.ArrayList is in module java.base of loader 'bootstrap';
this worked though
String[] linkString = ["ONOFF-3526", "ITSD-14523"]
Help us plant more trees
