automation add filed value
arno
Hi All
    We have been trying to use automaion add field value to comment recently.
    At first, "{{issue.filedname}}" could be displayed normally. However, after we translated this custom field, using the following methods failed to obtain the corresponding value:
   {{issue.filedname}}
   {{issue.customfieId_xxx}}
    I attempted to use the {issue+field name} format, but I couldn't retrieve the corresponding value, no matter which environment's field name I used.
arno
We have finally decided to unify the field names and no longer perform translation.
Thanks everyone help
June 7, 2025 edited
Hi @arno
For a question like this, context is important for the community to help.  Please post the following:
  • what version of Jira are you using: Cloud, Server, or Data Center
  • an image of your complete automation rule in a single image for continuity
  • images of any relevant actions / conditions / branches
  • an image of the audit log details showing the rule execution
  • explain what is not working as expected and why you believe that to be the case
Until we see those...
Smart values are name, spacing, and case-sensitive...and frequently do not match the field's displayed name on the Jira pages.  When an incorrect smart value is used, that returns a null value.
To learn the smart value (or custom field ID), field structure, and if it is supported by automation rules, please use this how-to article:
https://confluence.atlassian.com/automation/find-the-smart-value-for-a-field-993924665.html
arno
Hi @Bill Sheboy
   thank you for your reply
   we are use jira server, server version :8.13.3
   our automation like this:
June 9, 2025
Thanks for that information, and...
Please post an image of the audit log details showing the rule execution.  That will confirm which rule steps processed and if there were any errors.
Did you try the how-to article to confirm your smart values / custom field ID's are correct?
arno
hi @Bill Sheboy
    sorry,the log did not show any errors. As I mentioned, when I did not translate this field, I was able to obtain the corresponding value using any method.
June 10, 2025
arno
Hi @Bill Sheboy
    Yes, the field ID is correct.
     I once again referred to the official documentation and discovered this explanation
     If you're trying to access custom fields with translated names in your smart values, then use the language set for your rule actor user.
     I'm not quite sure. Do I need to add multiple rules to ensure that users obtain the correct field values in different language environments? just like this:
BUG ID:
{{issue.BUG测试ID}}
{{issue.BUGtestID}}
June 14, 2025 edited
This appears to be a known defect which was fixed in a later release than you are using: 10.2.1
https://jira.atlassian.com/browse/JIRAAUTOSERVER-1025
https://confluence.atlassian.com/jirasoftware/issues-resolved-in-10-2-1-1456346546.html
If you do not upgrade versions, you could try the workarounds noted in the defect, although I suspect they may not work to maintain the translated values.
Piyush Annadate _ACE Pune_
Try {{issue.field name.value}}
arno
hi @Piyush Annadate _ACE Pune_
    I have tried this way
   Before the translation field,
    {{issue.product}}    {{issue.product.value.value}}  {{issue.customfieId_14001}}   {{issue.customfieId_14001.value}}
   All these methods can obtain the corresponding values.
    When I translated "product", the above methods were unable to obtain the corresponding value and it was displayed as empty.
What type of field 'Product' is?
arno
    it's a test filed, product is a text filed
then that should be via the {{issue.customfield_XXXX}}; should work.
Aaron Williams
June 6, 2025
Hey @arno
What type of field is the custom field? And do you have a snippet of where it's used in your automation?
Aaron.
arno
hi @Aaron Williams
  thank you for you reply
   it is a text field,my automation just like this:
   product:
   {{issue.product}}
SERVER
