can add a JIRA dashboard to a Confluence Page?
zhang zining
I know how to add a JIRA Gadget to a Confluence Page,
but i do not know how to add a JIRA dashboard to a Confluence Page?
who can tell me how to do? thank a lot!
4 votes
MatthewC
September 26, 2012
The best answer is to export the Jira gadgets to Confluence one by one. Sorry but there is no quick way to do this
https://confluence.atlassian.com/display/DOC/Registering+External+Gadgets
Then you can create a Confluence page and add the Jira gadgets in locally. This wil use the application link between Confluence & jira. It's the "best practice" approach.
https://confluence.atlassian.com/display/DOC/Adding+JIRA+Gadgets+to+a+Confluence+Page
https://confluence.atlassian.com/display/DOC/Inserting+JIRA+Issues
https://confluence.atlassian.com/display/DOC/JIRA+Issues+Macro
the quick & dirty way, would be to use an iframe in a confluence page and embed the whole jira page using the URL
e.g.
http://jira.xxxxx.com:8080/secure/Dashboard.jspa?selectPageId=10780
Iframe macro
https://www.adaptavist.com/display/AtlassianConfluence/iframe+macro
Sharif Omar September 17, 2020
Thanks very much. Used the iframe macro and it works for me on Confluence Cloud.
Like • david.bickers likes this
david.bickers
June 2, 2021
The Iframe worked for me too. Thank you so much for sharing.
Jo Vasev
October 23, 2019
I am also looking to do this and so far have not found an easy way. Any ideas?
Thanks, Jo
Neel Desai November 17, 2016
@zhan zining  or @Matthew Cobby @Paulo Paulo I want to do same thing. I want to add JIRA Dashboard on confluence page. Is there anyone who got perfect answer of this question? Like, How can we do that?
Neel Desai
Deleted user March 6, 2021 edited
I don't think this is straightforward to do. It would be nice to have.
Gorka Puente _Appfire_
Hi Dan,
We just submitted for marketplace approval the Confluence version of a commercial app called Dashboard Hub. You can display dashboards in Jira or in Conflunce (with the new version) with data from Jira (also Bitbucket, Confluence, Statuspage, Opsgenie, Insight...). Here you can see a live dashboard here , publicly shared.
I can ping you as soon as it's publicly available in the marketplace.
Regards
Like • ViswanathanR likes this
ViswanathanR April 27, 2021
It seems only Cloud version is available. Do you have any plans to take to Server and DC versions too?
Like • Gorka Puente _Appfire_ likes this
We're waiting for the server version to be approved and next we'll release the DC version. Meanwhile, next week we're releasing Hybrid Dashboards. A Hybrid Dashboard is a dashboard that displays information from server, data center and cloud Jira and Confluence instances. In other words, you'll be able to connect to server/data center instances from your cloud dashboard.
If you need more information about dates for the server and data center versions, ping me: gorka at roninpixels dot com
Regards
Katerina Kovriga _Stiltsoft_
April 28, 2021
The Table Filter and Charts for Confluence app allows you to create dashboards based on the Jira Issues macro both for Cloud and Server/DC.
The only difference for the Cloud type of hosting is that you'll need to use the Table Toolbox macro to nest several macros, other steps won't differ from the documentation.
If you have any questions, please book a live demo with our team - we'll be glad to answer them.
PauloP
September 26, 2012
HI Zhang
I'm not quite sure, but you may try using JIRA Portlet Macro. For fruther details, please use the following link as your guide:
https://confluence.atlassian.com/display/CONF20/JIRA+Portlet+Macro
Anyway, you always have the opportunities to add multiples JIRA gadgets. So you may "reproduce" the JIRA's dashboard.
Paulo Renato
sim xing
Is there a way to add the dashboard directly instead of recreating it in confluence? Especially when JIRA gadget doesn't work in Confluence like roadmap gadget to show versions. @MatthewC @PauloP Thanks!
Like • 4 people like this
