can i create sub tasks automatically
IT Support June 14, 2015
Based on one entry thru service desk, we would like to create several sub-tasks in our team automatically.
Is that possible?
Example:
  • new user request -> entry in Service Desk with a specific issue type
  • based on variables (different systems and/or requirements for the new user) create one or more sub tasks to define a user id, setup logins for different systems, buy hardware, etc. etc.
  • possibility to create sub-tasks immediately?
5 votes
Bob Swift
June 15, 2015
Create on Transition for JIRA provides post functions for doing this. In your case review the following specific pages:
  1. Create Subtask post function
  2. Substitution variables
  3. How to create multiple issues
  4. How to create subtasks on initial issue create
Danny Coleman June 15, 2015
Just to add a little more to this plugin is ingrained in our workflow (hi, Bob!) - you'd want to add the "Create Subtask" post-function in the Create transition of the Service Desk issue's workflow. Be sure to move the "Create Subtask" post-function so that it fires after the "Creates Issue Initially" post-function!
Bob Swift
June 15, 2015
Good point :). I added a reference to the page (#4) in the answer.
Like • Orlov Stanislav likes this
IT Support June 22, 2015
Hi Bob, If I understand correctly, the post-function "Create Subtask" is created and provided by your add-on to Jira?
Bob Swift
June 22, 2015
Yes, Create on Transition for JIRA linked above.
Found it Bob, thanks! And just successfully used it in creation of a sub-task based on variables, very nice.
Joshwa Marcalle
January 24, 2018
Monique vdB
Community Manager
January 25, 2018 edited
@Joshwa Marcalle, please see our guidelines for vendors. Specifically, you need to identify that you are a vendor and also avoid spamming threads (particularly outdated threads) with links to your plugin.
Hi Alexej, The trigger would be a field with multiple selections possible (multi-select). To be more specific: the entry is a "new user form" entered by a manager i.e. and linked to an issue type. Custom field "Systems" with a multi-select option, so at the request of a new user multiple systems can be defined. As a result multiple sub-tasks are created to define the new user for several systems, each with it's own owner.
Alexej Geldt
June 14, 2015
its definitely possible. We have written a plugin that is doing similar tasks. i didn't quite understand what would be your trigger to create those subtasks? When issue of certain issue type is created?
