can i send a notification when i move an issue across projects?
Edward Geddes
i am looking for a way to send a notification (preferably as part of a notification scheme) when i move an issue from one project to another. haven't found anything online yet.
Jobin Kuruvilla [Adaptavist]
March 18, 2013
Edward Geddes
Hi Jobin, thanks for the response! So I may be missing something (and forgive me if I am being dumb) but I don't see where I'd trigger that event from when I select more actions --> move issue and then go through the move issue wizard.
March 19, 2013
The event is automatically thrown by the underlying code. You just need to add in the notification schemes to get notified.
Edward Geddes
thanks Jobin!
Sri Kanth November 16, 2015
Can anyone verify if the accepted answer works?
I see an Atlassian ticket here that is closed without implementation.
