can not query reserved character:square bracket [ ] in summary in jira 4.4.1
fabby
for example i have for jira issue with summary like follows,
amoi4.0
[amoi4.0]support
amoi4.0- fewat
[amoi4.0] not
1 and i can use summary ~ "amoi4.0" to search out the above four issues,
2 but use summary ~ "amoi4.0\\]" ,there is no result.
3 or use summary ~ "amoi4.0\]" ,it will say
Error in the JQL Query: '\]' is an illegal JQL escape sequence. The valid escape sequences are \', \", \t, \n, \r, \\, '\ ' and \uXXXX. (line 1, character 19)
why ?
Thomas Schlegel
fabby
hi,Thomas-S
you mean summary ~ "\\[" doesn't work because of JIRA's bug ?
and we have no resolution now?
Thomas Schlegel
seems so :-(
fabby
hi,Thomas-S
i met another problem,i can not use number in query (summary ~ "4.0") using one of my jira server A,the query result is empty.
but on another jira server B i can search out issues with summary contains "4.0".
i don't know what's wrong with the jira server A.
all my jira server version is 4.4.1
Thomas Schlegel
Are you sure there are issues with a summary "4.0" ?
Try do do the search with the simple search. Do you get some results with that ?
fabby
yes,i create one issue with summary “4.0”
and do the search summary ~ "4.0"
but query with no results.
i am wondering if i have installed some plugins that make jql something error
Thomas Schlegel
and did you try the simple search ??
fabby
yes,in simple search tab,set "Query“ to 4.0 gets no result.
Thomas Schlegel
maybe you could try reindexing your issues via admin console
fabby
i tried reindex ,but with no good luck.
i created another issue with summary “43265”,and summary ~ "43265" query returns no result too.
Thomas Schlegel
Hello all, has anyone else another idea ? If not, I think you have to ask then official Jira Support.
fabby
i resolve it ,set indexing language to Englist ,and do a re-index will solve the problem
Criztov
April 27, 2021 edited
Have you tried using this trick?
issueFunction in issueFieldMatch("project=ABC", "summary", "\\[BA\\]")
Originally posted by: @Mash Huang
https://community.atlassian.com/t5/Jira-questions/How-can-I-search-for-exact-text-in-square-brackets/qaq-p/395566
Register today
