×Hello,
Just testing the migration procedure to JIRA 7 and i'm facing an error when installing Subversion plugin.
No errors in log, but the timeout (60s) is hit when attempting to enable it, and the plugin remains "disabled".
Any clue on how to get extra info about the cause of this problem?
JIRA 7.1.1 / Subversion plugin 3.0.1
Thanks.
Also, I have about 150 SVN repositories defined ... I have been "playing" with the repos and Ive found this query that seems to show the repo's config in Jira:
select pe.id,property_key,propertyvalue from propertyentry pe join propertystring ps on pe.id = ps.id where property_key = 'svn.root';
In further tests Ive shut down JIRA instance and UPDATEd propertyentry/propertystring tables to replace all property keys starting with "svn" to "1svn" (to avoid using that info from SVN plugin).
Then the plugin starts in 1-2s.
In other tests I left only about 50 SVN repos with the "svn" and the rest (~100) as "1svn.XXXX". The plugin starts smoothly in 1-2s.
I think that the problem is somehow related to the number of SVN repositories ...
Try to investigate atlassian-jira.log.
Setup logs for com.atlassian.jira.plugin.ext.subversion to DEBUG and got the following error.
If I uninstall the Subversion plugin and re-install from scratch, UPM waits for 1 min before rendering the plugin as inactive:
2016-03-29 12:56:54,364 UpmAsynchronousTaskManager:thread-3 INFO root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (1): [com.atlassian.jira.plugin.ext.subversion], 60 seconds remaining 2016-03-29 12:56:55,364 UpmAsynchronousTaskManager:thread-3 INFO root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (1): [com.atlassian.jira.plugin.ext.subversion], 59 seconds remaining 2016-03-29 12:56:56,364 UpmAsynchronousTaskManager:thread-3 INFO root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (1): [com.atlassian.jira.plugin.ext.subversion], 1 seconds remaining 2016-03-29 12:57:53,381 UpmAsynchronousTaskManager:thread-3 INFO root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.plugin.util.WaitUntil] Plugins that have yet to be enabled: (1): [com.atlassian.jira.plugin.ext.subversion], 0 seconds remaining 2016-03-29 12:57:54,381 UpmAsynchronousTaskManager:thread-3 INFO root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.plugin.manager.DefaultPluginManager] Disabling com.atlassian.jira.plugin.ext.subversion 2016-03-29 12:58:03,147 ThreadPoolAsyncTaskExecutor::Thread 51 DEBUG root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.j.p.e.subversion.revisions.RevisionIndexer] Number of repositories: 137 2016-03-29 12:58:03,194 ThreadPoolAsyncTaskExecutor::Thread 51 INFO root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.j.p.e.subversion.messages.DefaultIndexMessageService] Registered IndexMessageConsumer: com.atlassian.jira.plugin.ext.subversion.messages.DefaultIndexMessageService$IndexMessageConsumer@22a25fe7 java.lang.IllegalStateException: LifecycleProcessor not initialized - call 'refresh' before invoking lifecycle methods via the context: NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugin.ext.subversion.atlassian-jira-subversion-plugin, config=osgibundle:/META-INF/spring/*.xml): startup date [Tue Mar 29 12:56:54 CEST 2016]; root of context hierarchy at org.springframework.context.support.AbstractApplicationContext.getLifecycleProcessor(AbstractApplicationContext.java:357) at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:877) at org.eclipse.gemini.blueprint.context.support.AbstractOsgiBundleApplicationContext.doClose(AbstractOsgiBundleApplicationContext.java:187) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$501(AbstractDelegatedExecutionApplicationContext.java:60) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$2.run(AbstractDelegatedExecutionApplicationContext.java:194) at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.normalClose(AbstractDelegatedExecutionApplicationContext.java:190) at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.close(DependencyWaiterApplicationContextExecutor.java:382) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.doClose(AbstractDelegatedExecutionApplicationContext.java:214) at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:836) at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager.closeApplicationContext(LifecycleManager.java:326) at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager.access$200(LifecycleManager.java:51) at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$2.run(LifecycleManager.java:291) at org.eclipse.gemini.blueprint.extender.internal.util.concurrent.RunnableTimedExecution$MonitoredRunnable.run(RunnableTimedExecution.java:55) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) 2016-03-29 12:58:03,194 ThreadPoolAsyncTaskExecutor::Thread 51 DEBUG root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.j.p.e.subversion.revisions.RevisionIndexer] Number of repositories: 137 2016-03-29 12:58:03,194 Gemini Blueprint context shutdown thread2 INFO root 835x80x1 12xmkfj a.b.c.d /rest/plugins/1.0/com.logister.jira.logister-key [c.a.j.p.e.subversion.messages.DefaultIndexMessageService] Unregistered IndexMessageConsumer: com.atlassian.jira.plugin.ext.subversion.messages.DefaultIndexMessageService$IndexMessageConsumer@22a25fe7 2016-03-29 12:58:03,194 ThreadPoolAsyncTaskExecutor::Thread 51 ERROR root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [o.e.g.b.e.internal.support.ExtenderConfiguration] Application context refresh failed (NonValidatingOsgiBundleXmlApplicationContext(bundle=com.atlassian.jira.plugin.ext.subversion.atlassian-jira-subversion-plugin, config=osgibundle:/META-INF/spring/*.xml)) org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'schedulerLauncher': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:216) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:299) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:755) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:757) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325) at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290) at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) 2016-03-29 12:58:03,194 UpmAsynchronousTaskManager:thread-3 DEBUG root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] onPluginDisabledEvent removing delegate for [com.atlassian.jira.plugin.ext.subversion] 2016-03-29 12:58:03,194 ThreadPoolAsyncTaskExecutor::Thread 51 ERROR root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [o.e.g.b.e.i.dependencies.startup.DependencyWaiterApplicationContextExecutor] Unable to create application context for [com.atlassian.jira.plugin.ext.subversion.atlassian-jira-subversion-plugin], unsatisfied dependencies: none org.springframework.beans.factory.BeanCreationNotAllowedException: Error creating bean with name 'schedulerLauncher': Singleton bean creation not allowed while the singletons of this factory are in destruction (Do not request a bean from a BeanFactory in a destroy method implementation!) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:216) at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:299) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:194) at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:755) at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:757) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325) at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85) at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290) at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745) 2016-03-29 12:58:03,210 UpmAsynchronousTaskManager:thread-3 DEBUG root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.jira.plugin.JiraPluginManager] Plugin with key 'com.atlassian.jira.plugin.ext.subversion' has been disabled. 2016-03-29 12:58:03,225 UpmAsynchronousTaskManager:thread-3 DEBUG root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.jira.plugin.JiraPluginManager] Disabling plugin with key 'com.atlassian.jira.plugin.ext.subversion' without persisting. This should occur if this plugin depends on a plugin that is currently being upgraded 2016-03-29 12:58:03,225 UpmAsynchronousTaskManager:thread-3 ERROR root 835x163x1 12xmkfj a.b.c.d /rest/plugins/1.0/installed-marketplace [c.a.plugin.manager.PluginEnabler] Unable to start the following plugins due to timeout while waiting for plugin to enable: com.atlassian.jira.plugin.ext.subversion
