can't sort by scripted field
Jason Galm June 27, 2014
I have a scripted field that only returns the issues resolution date.
I can't use the result in a JQL statement or even use it as a column to sort by.
I have the search template set to date time picker.
JamieA
June 28, 2014
Is there any error? Make sure you have modified a few issues to ensure their value is in the index.
To make new fields work properly you have to reindex every issue associated with the field.
Jason Galm June 29, 2014
Ahh I forgot you had to reindex when you change the script, that fixed it. Thank you.
I didn't think it was the script because it is litterally one line, return issue.getResolutionDate()
Register today
