with JIRA v7.1.9#71013 and JIRA rest API 4.0.0
Scala code:
case class JiraFieldDefinition(id: Long, fullIdForSave: String, typeName: String, itemsTypeIfArray: Option[String])
and then processing for custom fields:
case _ =>
val fieldSchema = customFieldResolver.getId(fieldName)
if (fieldSchema.isDefined) {
val fullIdForSave = fieldSchema.get.fullIdForSave
val valueWithProperJiraType = getConvertedValue(fieldSchema.get, value)
issueInputBuilder.setFieldValue(fullIdForSave, valueWithProperJiraType)
def getConvertedValue(fieldSchema: JiraFieldDefinition, value: Any) : Any = {
fieldSchema.typeName match {
case "array" if fieldSchema.itemsTypeIfArray.get == "string" => List(value).asJava
case "array" if fieldSchema.itemsTypeIfArray.get == "option" =>
List(
new CustomFieldOption(fieldSchema.id, null, value.toString, Seq().toIterable.asJava, null)
).asJava
case "number" => ValueTypeResolver.getValueAsFloat(value)
case _ => value
so, to summarize: this code goes through custom fields. it works fine for a custom "label" where an array of strings is expected. ( case "array" if fieldSchema.itemsTypeIfArray.get == "string" )
but it fails for a custom field called "custom_checkbox_1" with ID 10102 and customId=customfield_10102.
(see the second "case" for array+option).
the error I get is:
ErrorCollection{status=400, errors={customfield_10102=Invalid value '10102' passed for customfield 'custom_checkbox_1'.}, errorMessages=[]}
