change parent status without executing transition - from subtask
peter novak
August 16, 2012
hello
is it possible to change parent status to a given value (strictly to status "Error") without executing the transition to this state (because in transition i am auto creating a subtask). And i want to change parent status in transition between states of his son.
thank you :)
Nic Brough -Adaptavist-
August 16, 2012
No.
The only way to change a status is to go through a transition.
For your case, your spec seems to be "if something is done to a child issue, then in some cases, I want to change the status of the parent". With the caveat that you do not want the parent to go through the transition you've got that creates more sub-tasks.
To do that, I would be strongly tempted to create a second transition, without the "create subtask" function, and trigger that instead. I'd then protect it with a condition of some sort, so that the users only see the original transition (I think you'll need a spot of thought and coding for that)
peter novak
October 9, 2012
see https://answers.atlassian.com/questions/77307/change-wf-state-after-all-subtask-are-closed
i have solved this problem with
Script Runner (https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner)
this plugins has build in example:
  • Auto-transition parent when all sub-tasks are resolved
I add this post script function to "Close" transition on subtask (in IE i cannot add this function, try it in Firefox ;) ) and it works nice :) (subtsask must have resolution!)
enjoy
Register here ⬇️
