Hey guys, i installed Jira, confluence and Service Desk on 3 different VPS machines, but all of them are with serverIP:8080 and i want to point with a subdomain on this, like jira.mycompany.com and this will redirect to jira, how to do this in jira?
my subdomain is pointing on this IP adress.
just to clarify it. I want do it like this.
Jira.mycompany.com -> IP_FROM_MACHINE_1
Conf.mycompany.com -> IP_FROM_MACHINE_2
How can i add Service Desk to Jira? For me it looks like a seperate thing.
Thanks in Advance!
Service Desk is an application for Jira. Go to Admin -> Manage Applications to install it.
The setup of your urls is best done with a proxy server.
Most of us use proxies to do this. A proxy can take the existing installations pretty much as you already have them (ok, you have to edit the server.xml to tell the Tomcat it is behind a proxy) and serve them up on different urls. You can use the same ports on different installs, and have the proxy drop the ports completely.
Additional question - why Service Desk separately to Jira? To get the best integration, you usually take an existing Jira Core or Jira Software and add Service Desk to it.
8080 is the port the URL (jira.mycompany.com) responds to for html traffic. If you have 3 machines you should have 3 URL; one for each which will respond to port 8080
