check single-user field is empty or not then update assignee to single-user field
Jessy Li January 31, 2016
Hello, I have a field called Bug Examiner. Can I do post action in transition that 1.check if the bug examiner is not empty, then update assignee?
Vasiliy Zverev
January 31, 2016
Here it is:
if(ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Bug Examiner").getValue(issue) == null){
    //Set new asignee
    issue.setAssignee(ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser());
    //store changes to database
    ComponentAccessor.getIssueManager().updateIssue(ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser(), issue, EventDispatchOption.ISSUE_UPDATED, false)
Let's build A Rovo Agent 🤖
Save your spot
