How can I display the Stories associated with an Epic on the epic screen and how do I how can I display the epic associated with the the story on the story screen?
Why is Jira so difficult to use???
Hi Jerry,
You can view both the Epics and the Stories they're associated with on one screen with Agile Docs (a plugin I created). It gives you a birdseye view of your project so you can see how everything is linked together.
Issues including stories in an epic do display in an epic, you can see this in the section of the epic that is called Issues in this epic. if you include the epic name and epic link fields in a story, you should get what you want.
Can you screenshot the issue if this doesn’t help?
