class name for jira listener
Kota Sreenivasa Shravana Kumar
I would like to get a notification from JIRA whenever an issue gets deleted. If I am right, this can be achieved through JIRA listeners.
What will be the class name to be used to achieve the same ?
Renjith Pillai
June 2, 2013
You can also get it if you configure your project notification scheme to notify you. But if your need to get notified for every issue in the instance without configuring the project notification scheme, listeners is the way to go.
Timothy
June 2, 2013
Well.. You may not need to use a listener per se. What you need to do is to go into every Notification Scheme that you have and add yourself to the Issue Deleted event.
