close subtasks with closed parent
Greg Mackey April 17, 2015
Is there a way i can close all sub-tasks that have a closed parent?
Andy Nguyen
April 17, 2015
Hi Greg,
If you use Script Runner for JIRA Server, you can run the following JQL to search for all non-Closed subtasks of a specific issue (that you know is Closed):
issueFunction in subtasksOf("issuekey = DUMMY-1") AND status != Closed
In this example, I'm searching for all non-Closed subtasks of DUMMY-1. You can surely modify the query according to your real scenarios.
If you'd like to look for all non-Closed subtasks of all Closed issues, you can use this:
issueFunction in linkedIssuesOf("status = Closed", jira_subtask_outward) AND status != Closed
Then you can use Bulk Change to close all of them.
Cheers.
Andy Nguyen
April 17, 2015
Just for your info, here's the list of Scripted JQL Functions by Script Runner: https://jamieechlin.atlassian.net/wiki/display/GRV/Scripted+JQL+Functions
I am not looking to close sub-tasks on parent task closure. I am looking to close sub-tasks that have a parent already in a closed state.
Gabor Nagy _Midori_
April 17, 2015
I believe based on the first post-function example, you can write your own Groovy script. You just have to query all the issues you need and loop through them as you see in the example. Here is how to execute a JQL query: https://jamieechlin.atlassian.net/wiki/display/GRV/Miscellaneous+Groovy+Scripts#MiscellaneousGroovyScripts-ExecutingaQuery
Gabor Nagy _Midori_
April 17, 2015
Hi Greg,
See the solution here: https://answers.atlassian.com/questions/47073
