[closed] Scripted Validator: Add Parameters To Validator... Add button not working!
Marco Colageo
I'm using the groovy plugin to define a 'Scripted Validator' rule behind a transition but the 'Add' button in the ' Add Parameters To Validator' page does NOT submit the page.
Any ideas?
Marco Colageo
The 'Add button' problem seems to be one of the issues related to Groovy Runner v2.0.7 installed in JIRA v4.x. I had tried also the latest version of the plug-in which did not work too because it is JIRA 4.x compatible. With my current JIRA set-up I did not find any way to use the Groovy Plug-in unfortunately.
Looking forward to move towards JIRA v5 and the latest version of the plug-in.
Ps. Jamie, Wolfgang, many thanks :)
Wolfgang Fellner
Which browser do you use?
I have the same problem using Opera, but it works with Firefox and InternetExplorer.
JamieA
November 19, 2012
I believe it doesn't work with IE, should work with everything else. Not tested opera. This is a known issue.
Wolfgang Fellner
Jamie is right - it looks like it does not work with current IE versions (9 and 10) any more.
I thought it has worked with older versions, but not sure any more.
At least it works with Firefox.
JamieA
November 21, 2012
2.0.7 was never available for 4.3... choose the right version for your jira from https://marketplace.atlassian.com/plugins/com.onresolve.jira.groovy.groovyrunner.
Marco Colageo
Yes, the plug-in v2.0.11 seems to be only for Jira 5.x . When I tried to use the plug-in on Jira 4.3, it caused blocking errors (no issues o projects displayed more).
JamieA
November 20, 2012
Yeah, it was a different problem than I thought. But I think that version is only for jira 5.1+.
Marco Colageo
Here we are: Jira 4.3, groovy runner 2.0.7
Firefox 16.0.2, Chrome 22.0, IE8
I've noticed that there is the new version 2.0.11 of the groovy runner which says "Fixes an issue where you can't add new workflow functions". I'm going to update the plug-in first...
JamieA
November 19, 2012
Weird. What's your jira version and plugin version?
JamieA
November 19, 2012
Also can you check the jira log for errors.
Marco Colageo
Sorry for not mentioning it before. I've tried it in Firefox, Chrome and IE with no positive result. It seems like the button being disabled (althought is clickable).
Is there any alternatives to groovy validators?
