cluster.properties file get jira.node.id ID automatically, like the hostname.
Lessandro March 19, 2018
Hello, I would like to edit the cluster.properties file to the parameter jira.node.id get an ID automatically, for example the hostname.
It is possible? If so, how?
Thanks in advance!
Tran Dien Hien September 26, 2021
@Lessandro
You mean, You did the same as Jira for Confluence ?  Could you please explain more about this ?
Thank you so much
Jeff Shepherd
September 27, 2021 edited
In /opt/confluence/bin/setenv.sh (your directory may differ) I have the following line:
CATALINA_OPTS="-Dconfluence.cluster.node.name=${HOSTNAME} ${CATALINA_OPTS}"
When Confluence starts up this automatically sets the name of the node to the hostname.
On the Jira side, you can't have a variable in the cluster.properties file. The script from @Lessandro is a hack useful trick that modifies the file before Jira is run.
Tran Dien Hien September 28, 2021
Thanks @Jeff Shepherd
Tran Dien Hien September 25, 2021
@Lessandro
Do you have any idea for Confluence cluster? I'm facing the same issue for Confluence cluster
Lessandro March 20, 2018
I got it.
Basically I created a bash script to add automatically the hostname in the file. Something like this:
HOST=$HOSTNAME
JIRANODE="jira.node.id = "$HOST
sed -i "2s/.*/$JIRANODE/" /var/atlassian/application-data/jira/cluster.properties
This bash is executed in every reboot via cron.
Jeff Shepherd
December 7, 2020
Ick.
In Confluence you can do the $HOSTNAME trick. Sad that you can't do something similar in Jira. Not the answer I was hoping for, but it is an answer.
